Other than manually inserting something like
<script src="https://ajax.googleapis.com/ajax/libs/j ... "></script>
into the end of the HTML, I can't see how to get the program to generate such an entry automatically.
In the advanced section of the property inspector, there's a field where you can specify a few jquery versions (but not the latest, nor a non-"min" version) but that doesn't seem to help.
Thanks in advance
How do I get jquery included when I preview?
Re: How do I get jquery included when I preview?
jQuery will only be added when it's required for one of the built-in objects.
If you have custom code that needs jQuery then you can add it as a 'resource' for the HTML object, enter:
$JQUERY$
$JQUERY$
