Link Style with Transparent background
Hey,
I am trying to configure a new Link Style and to disable the Text Background but it seems to be impossible.
How can it be done?
Please see screenshot attached.
Re: Link Style with Transparent background
By default, the background of a link style is transparent.
If you have selected a color then you can reset it to transparent by setting the color to: 254, 254, 254 (RGB)
Thanks Pablo!
