GDPR Note
GDPR Note
Hey,
I would like to add a GDPR notification with a (X) sign on it in the footer / header / tooltip window.
Does anybody has any suggestion how can I add such thing with the software?
Re: GDPR Note
Maybe you can use a dialog?
