Google recaptcha and the GDPR
psaldari
Post by psaldari » Wed Jul 17, 2019 9:58 am
Hello,
anyone knows if the google recaptcha violate the GDPR?
In my site I don't collect any data (no cookies) and my dubt is: recaptcha send dato to google and it store this data?
There is other (free) alternatives to google recapcha?
All the best
Paolo
Re: Google recaptcha and the GDPR
Post by Pablo » Wed Jul 17, 2019 11:22 am
I'm sorry, I do not know the answer to this.
But if this is true then I am sure you will find it somewhere on the Internet.
I am not aware of any alternatives that are free.
psaldari
Post by psaldari » Wed Jul 17, 2019 2:48 pm
OK, I have the answer, google recapcha send lots of data to google...
I removed it to my site, now I investigate if I can find a good alternative for the spam problem; any suggestion?
Paolo
psaldari
Post by psaldari » Wed Jul 17, 2019 3:24 pm
On my search I find the HoneyPot method*, is it possible to integrate it on my project?
* insert an invisible field to the human visitor but visible to the bot, if the bot fill this field the email cannot be sent
Post by Pablo » Thu Jul 18, 2019 6:21 am
You can use the HTML object or Page HTML to add custom code to the page.
http://quickandeasywebbuilder.com/add_html.html
Unfortunately, I cannot help you with the implementation of third party scripts because for me that may also take a lot of time.
psaldari
Post by psaldari » Tue Jul 23, 2019 3:24 pm
OK, I can understand it, thank you anyway.
I add a editbox without border and trasparent. I add a condition: if not empty>disable>submit
Do you think it can work like a honeypot trap?
Paolo
Post by Pablo » Tue Jul 23, 2019 5:39 pm
No, I do not think that will work.
Spammers can easily disable JavaScript to by pass this
