Creating a container
Hey,
I was wondering if it's possible to build a container like the one in the example here.
(I am sorry for the different language)
To summarise, I am looking to have a feature where if you press on the category it updates the layer below it with different content. Can we make such thing with Quick n Easy Web Builder?
Thanks,
Re: Creating a container
Maybe this template will be helpful?
http://www.quickandeasywebbuilder.com/s ... candy.html
Yes, How can I create the products section?
You can download the template here:
http://quickandeasywebbuilder.com/templates8.html
This is an advanced feature and it requires some HTML/script knowledge.
Thanks Pablo,
Can I make it work with different objects? Such as Cards / Text / Layer.
Thanks!
Yes, but then you will need to modify the script.
Unfortunately, I cannot help you with creating custom script because for me that would also take a lot of time.
Can you consider adding this feature to the program so everyone will be able to enjoy it?
There is no easy way to implement this a generic option that works with everything. Advanced functionality like this will always require some scripting.
I really need this feature. Even just for Layers / Text.
I'm sorry, there is no standard solution. This will require a custom script.
