Creating a blog
Creating a blog
Hey,
I was wondering what is the best practice in order to integrate a blog inside my website using Quick 'n Easy Web Builder.
Is there maybe a template for blogs? or an extension you heard of?
Thanks.
Re: Creating a blog
There is no standard blog option, this requires a third party script/with database which must be installed on the server.
You can use the HTML tools to integrate external code.
http://quickandeasywebbuilder.com/add_html.html
However, this is not something I can help you with, because for me this may also take hours or days work.
Re: Creating a blog
I don't think the reply is any related to my question.
Re: Creating a blog
I'm sorry there is no standard solution for this.
Re: Creating a blog
Post by mexman »
Hi Morris:
Pablo sent you the complete and best possible answer:
He told you, "There is no standard blog option". Full stop. In case you have any better idea of coding or at least HTML (because you did not mention your skill level) he explained to you, what you can do to implement a blog function if you find one of your convenience.
So your answer "I don't think the reply is any related to my question." was really out of focus!
Re: Creating a blog
mexman wrote: Thu Jul 25, 2019 6:55 am Hi Morris:
Hi Michael,
I was asking if there's a blog extension for Quick 'n Easy Web Builder as I know there are for WYSWIYG Web Builder which add a mini blog to your website.
The answer could be No or Yes as I am an old WWB user who is not aware of what exists here compared to WWB.
I use Quick 'n Easy Web Builder because I don't know how to develop back-end / front-end solutions.
I highly appreciate Pablo and his support and just wanted to make sure he understands my question, this reply of yours was unnecessary.
Thank you and have a lovely day!
Morris.
