Events for Cards
Events for Cards
Hey,
I am trying to add a Button on a Card Object where there's an event of Onclick show Text object.
This Button is also a Link to another page in another tab on the same browser.
The event I configured is not working and I was wondering if you know why.
Re: Events for Cards
To be able to help you, I need to see what you have done.
Note however that a button cannot have events and be a link at the same time.
http://www.quickandeasywebbuilder.com/f ... 10&t=37833
I followed these steps:
1. Added Card.
2. Added Text1 + Unhide it.
3. Edited the card.
4. Edited the 'Read More' button and added Event: Onclick Show Text1.
5. Nothing happens when I press the Button.
When using this workaround of adding return true; can we have a link and an Onclick event?
What I am trying to achieve is to have a Button which is a Link and once you click on it the Button text changes OR to Display a Dialog object onClick. Got any suggestion how can it be done with Quick 'n Easy Web Builder?
Thanks.
Thanks for the information.
The issue should be fixed in version 6.2.3
http://quickandeasywebbuilder.com/forum ... =1&t=45917
