User defined meta tags
Hey,
I am having an issue where when i add User defined meta tags to my page settings the whole page height begins from a different size (in Mobile/breakpoint mode).
Also, when the page loads you can see all the meta tags loading and then the page loads, is it supposed to be like that?
You can see an example here:
http://www.couponsexplorer.com/yango.html
It's causing issues with the masterpage footer. And giving an unknown height between the header to the site content.
See how it looks on the software:
Compared to the live version.
Thanks.
Re: User defined meta tags
The meta tags you have added are not correct.
You should add valid meta tags, not just text only.
Please see the help for examples.
