I had a pc meltdown, but the backup files are older ones, not the last files I worked on. The latest files are on my server.
Can I download all the html files from my server back to Quick and Easy, if yes, what is the best method, thank you.
downloading files from server
- Contact:
Re: downloading files from server
The HTML files cannot be used to restore your project.
Didn't you make a backup of the qwb file or the complete project folder?
http://www.quickandeasywebbuilder.com/f ... 10&t=41168
- Contact:
of course I did. I found the right files on my backup.
