Index search
Cba
Index search
Post by Cba »
I’ve seen that it’s possible to have an index for searching the site but is it possible to also add a slider style index. I’m looking for a new website builder and I want to include alphabetical sliders on the new site. I have a music lesson website for multiple instruments with over 300 songs and I want to use the slider so people can find the songs via a drop down menu from the index slider. The reason I don’t want to use just the basic search is because some songs are listed more than once depending on the instrument. I want to add individual index sliders for each instrument.
Re: Index search
I'm sorry, there is no standard solution, because this is very specific.
This will require a custom or third party script.
You can add custom scripts via the HTML object.
