Installation problem
askwara
Post by askwara »
Hello,
I re-installed my Linux Mint 19 on my laptop. Previously I had QNEWB 5 installed and it worked very well. However after re-installing the OS it doesnt work any more. I tried QNEWB 7 and it works trial version smoothly. I installed all needed 32 libraries on my 64 Mint version, including libpng 12.
I downloaded QNEWB 5.4.2, extracted files, double click or auto run prompt on qnewb, nothing happens.
When try to open zip file with GDebi Installer it says: "...is not Debian package".
What is the solution to this problem?
Maybe could I get access to .deb file, instead of .zip?
Thanks!
Alex
Re: Installation problem
Version 5 is only available as 32 bit version.
So, you will need to install 32 bit support.
Note that QWB5 is no longer supported.
