Hi, I have a problem withe the Google fonts in WB7 on Mac OS (High Sierra).
I have added the fonts Nunito, Nunito Light and Nunito ExtraLight with the Google font manager. They can then be selected while editing text.
But only selecting Nunito works, if I try to use the other 2 variants it does not work and the text becomes Arial.
WB7 Google fonts
Re: WB7 Google fonts
I have updated QWB 7.0.3 to support google font variants.
I got a question concerning google fonts as well. I used QNEWB 5, and build my webpage in it using the google font Noto ***** JP.
All was well and it also displayed correctly. I now updated to 7 because of clean install (5 wasn't available anymore) and the google font manager just shows Noto ***** and Noto Sans, but not all the other variations of the font as shown here: https://fonts.google.com/?query=noto
Is it possible to have them as well in the google font manager?
Also something is weird with the regular Noto *****, as it appears as arial in the viewport as well as the font manager.
PS. Also Work Sans just appears as Arial.
On which platform are you using the software?
You are right, the Mac version includes an older version of the google font list.
I will include an updated version of the list in the next update.
