iPadOS
michling
iPadOS
Post by michling »
It seems the display of a website using the fix for IOS, does not display properly using iPadOS?
Tried iPadOS 13
Just checking...
Re: iPadOS
There are no known issues.
Can you please be more specific?
michling
Re: iPadOS
Post by michling »
If you look at this website with an iPad running iPadOS you can see what I mean.
https://mespn.com
Compare it running on a Mac or iPhone running Mojave and IOS 13.
The background graphics in the Layout Grids and Layers is Zoomed in too much?
I have re-Published using QEB version 7
Re: iPadOS
Unfortunately, I do not have iPadOS yet. So, I cannot verify if there is a problem until next week when it's officially released.
But it seems to work ok on the iPhone with iOS13.
Note that 'Safari fix' will disable background-attachment: fixed property, so if that does not work then it may be a bug in iPadOS.
Many websites use this method to workaround issues with iOS not supporting the fixed attribute.
See also 'known issues'
https://caniuse.com/#feat=background-attachment
michling
Re: iPadOS
Post by michling »
Sorry, I have iPadOS 13.1, so I thought iPadOS 13 was already out.
Anyway, yes it works fine with IOS 13 and of course Mac.
Thanks for the quick reply, look forward to hearing about iPadOS...
michling
Re: iPadOS
Post by michling »
Pablo,
I just found a way for iPadOS to display the webpage correctly.
Just turn off the Request Desktop Website for All Websites. Hopefully you can see the screen grab below.
Then iPadOS displays the website the same as the iPhone...
So, I don't know if that is considered a bug or a feature, but it works for me.
Just thought you might want to know.
Re: iPadOS
This is not a bug. The setting changes the way the browser identifies itself. So, there 'fix' will no longer be active because the page does not know it's being displayed on an iPad.
michling
Re: iPadOS
Post by michling »
So I guess their fix breaks your fix. At least there is a way to display properly. To bad I cannot include some code to check if running iPadOS...
Oh well, thanks for the reply.
Re: iPadOS
Note that this is not related to the software. It is known issue, but apparently Apple has no plans to fix it.
