Dialog properties
Dialog properties
Hey.
I am using the Dialog feature and I am trying to understand 2 things:
1. On the properties I have: Close on escape: True.
Even though it's enabled I can not exit the dialog on ESC.
2. How can I control the position of the dialog on the screen? I want to control where it's displayed on the screen.
I tried playing with the Margin setting but it does not change any thing.
This can be seen here:
https://www.couponsexplorer.com/glassesdirect.html
Thank you.
Re: Dialog properties
1. It seems to work correct for me. Note that this option only applied to jQuery UI, Bootstrap does not support this.
2. Set the 'alignment properties to 'absolute position'
Pablo wrote: Thu Oct 31, 2019 3:14 pm 1. It seems to work correct for me. Note that this option only applied to jQuery UI, Bootstrap does not support this.
I did and now it works like this: https://www.couponsexplorer.com/bolt.html (Click on the View Code button).
Why is that?
What is the exact problem?
Note that you have added valid code to the page, so this may cause issues.
