External script source
Hey,
I noticed that because of one of the application updates when adding external javascript sources (or sources in general they do not work).
When opening the browser Inspect -> Network -> I get this error: https://www.couponsexplorer.com/%E2%80% ... s%E2%80%9D
for this code: <script src=“https://cdn.jsdelivr.net/npm/clipboard@ ... ”></script>
Why is the software started adding my domain as the first path?
See reference here: https://www.couponsexplorer.com/page2.html
Thank you.
Re: External script source
This has nothing to do with the software.
The code will be published "AS IS".
Maybe there is a problem with your browser?
It's happening in any other browsers as well. Does it load fine on your browser?
If you view the code of the page, then you can see that code has been inserted exactly as you have entered it.
But it looks like you have used the wrong quotes in the code.
should be
<script src="https://cdn.jsdelivr.net/npm/clipboard@ ... "></script>
Pablo, thanks for the reply.
I don't know what caused it but I have not touch the code on the rest of my website pages and this has been changed automatically from: “ to ".
Now I need to go over every page and change the script again. This is odd.
There seems to be a bug with my project since the last update.
Everytime I open Page HTML.
It changes the code from: “ to " even though I just updated it. It ruins it again. Please assist.
I'm sorry, but the software will not change the quotes by itself. Your code will be published exactly as you entered it.
But maybe you have enabled 'smart quotes' in your system configuration?
