Fixed footer
Fixed footer
Hey,
I would like to update the footer of my website to be fixed to the bottom of the user's browser window size.
For example on this page: https://www.couponsexplorer.com/about.html
If I am using a browser window which is more than 800 pixels the footer is not fixed to the bottom of the page.
See screenshot below:
Can it be done with Quick n Easy Web Builder?
I am using this masterpage: https://www.couponsexplorer.com/master-page-rwd.html
Thank you.
Re: Fixed footer
Set the footer mode to 'fixed'
Re: Fixed footer
I did and now it's hovering the rest of my content.
Do you know how I can fix it?
You can see here: https://www.couponsexplorer.com/about.html
Re: Fixed footer
The fixed footer seems to work correct. This is how it is suppose to work.
Re: Fixed footer
But the footer should be displayed only if I get to the bottom of the page and not hover the content if my screen is smaller.
Re: Fixed footer
I'm sorry, that is not how it works. A fixed footer will always be visible. It's either fixed or floating.
To make make sure that the bottom of the content is also visible, add extra content to the page. For example, add margin at the bottom of the last element.
Re: Fixed footer
I did and it didn't change anything.
Re: Fixed footer
You will have to add extra content, with the same height as the footer.
Re: Fixed footer
Why is there a limit of margin not bigger than 99 pixels? If I could put 200 pixels, this could solve the issue.
Re: Fixed footer
I'm sorry, currently the margin cannot be bigger than 99.
I usually use a (transparent) line or shape to create a spacer.
Re: Fixed footer
Alright thanks I will try that in the meantime.
