[Resolved] Problems cloning a page
Cantenac
Post by Cantenac » Thu Jan 09, 2020 6:07 pm
Hello
I'm just building my first site using QWB, based on a Flex Grid (using version 7.1.1 64bit on Windows 8.1).
I'm having problems cloning a page. It appears to work initially - everything on the default page looks fine.
However, if I click on a breakpoint the associated layout grid is mostly missing, replaced by a default layout, and consequently most of the content had gone. And if I return to the default view that's been changed to the default layout with missing content.
Am I missing something, or is this a bug?
Re: Problems cloning a page
Post by Pablo » Fri Jan 10, 2020 7:31 am
There are no known issues with cloning.
Do you have a demo project and step by step description how to reproduce this behavior?
Cantenac
Post by Cantenac » Fri Jan 10, 2020 9:39 pm
Yes, I'll email you a demo shortly.
Post by Pablo » Sat Jan 11, 2020 8:57 am
Thanks for the demo project.
I was able to reproduce the problem based on the provided information and it will be fixed in the next update.
Post by Pablo » Sat Jan 11, 2020 6:35 pm
The problem should be fixed in the latest update:
viewtopic.php?f=1&t=46041
Cantenac
Post by Cantenac » Tue Jan 14, 2020 1:20 pm
Yes, the latest version seems to work fine. Thanks for the quick fix!
