[Resolved] How do I get a responsive menu to work below 640px?
Cantenac
Post by Cantenac » Thu Jan 09, 2020 7:29 pm
Hello
I'm just building my first site using QWB, based on a Flex Grid (using version 7.1.1 64bit on Windows 8.1).
I've just spent several hours trying to find a menu that works below a breakpoint of 640px.
Full Screen Menu looks ideal, however it doesn't appear where it should; instead of appearing top left of the page, it appears at the bottom right, with 2/3 of it off screen, irrespective of the browser (it seems I can't upload a screenshot?), though it works fine when clicked.
Responsive Drop Down Menu is doing similar.
Responsive Menu appears correctly as a hamburger icon, but the entire page layout is thrown off when it's clicked.
Ideas welcome...
Cantenac
Re: [Resolved] How do I get a responsive menu to work below 640px?
Post by Cantenac » Fri Jan 10, 2020 1:13 am
I've rebuilt the page and now have the Full Screen Menu working without problem at the smallest break point :)
Post by Pablo » Fri Jan 10, 2020 7:32 am
All the mentioned menus should work.
To be able to help you, I need a demo projetc so I can see all your settings.
