Looking for .deb version 6
Sijtse
Post by Sijtse » Sat Jan 11, 2020 5:08 pm
I am looking for the .deb installation file for version 6. The only file I see for that is a zip-file. Impossible to tell whether that's 32 or 64 bit. I never got version 6 installed anyway (zit nor .deb) despite asking here a few times. The only response I ever had and have ever seen was for Ubuntu based distro's. I have always used fedora.
Now I have Ubuntu installed and was wondering if I could get it to work now. You'll understand that I am not willing to pay again for a product (a version) that never worked anyway before I am convinced that now, under Ubuntu, it will work.
The .deb for version 7 seems to work so I am hopeful.
Cheers,
Sijtse
Re: Looking for .deb version 6
Post by Pablo » Sat Jan 11, 2020 6:24 pm
The zip is 32bit otherwise it would have '64' in the filename.
The files in the zip are exactly the same as in the Debian package. The only difference is that they will be copied automatically to the application folder.
The Debian package for version 6 (64bit) can be downloaded here:
https://www.quickandeasywebbuilder.com/ ... _amd64.deb
32bit:
https://www.quickandeasywebbuilder.com/ ... 0_i386.deb
Sijtse
Post by Sijtse » Sun Jan 12, 2020 8:45 pm
Thank you very much Pablo!
