Grids using a template
Hey,
I am using the 'dividers' template and I am trying to understand how can I add new Grid layers between current layers.
For example in the template home then services, so I would like to replace between their order / add a new layer between them. Is that possible? If so how?
It seems like everytime I try to add new grid layer then it's automatically being added to the bottom of the page.
Thank you.
Re: Grids using a template
You can change the order of floating elements with the arrange tools (move up/move down).
http://www.quickandeasywebbuilder.com/f ... 10&t=43910
