hyperlink text in bullet list mis-aligned
yvwinteler
Post by yvwinteler »
Hello
I'm using version 7.1.2, and having problems with the text of hyperlinks which is sometimes not aligned properly, when used in bullet lists.
For instance on page https://climatgeneve.ch/actualites.html, the word "affaibli" in the sentence "Mené par la majorité PLR-UDC, le Conseil national a tellement affaibli la loi CO2 que les Vert'lib" starts on a new line (on a display > 1000 px), and is slightly lower than the end of the sentence "la loi CO2 que les Vert'lib,"
This problem occurs only with Google Chrome - with Firefox, the alignment is correct. I've tried changing the font to Arial, removing the format on hyperlinks, removing the master pages, it dosen't make any difference.
How can I solve this problem ?
Thanks for your help !
Yvonne
Re: hyperlink text in bullet list mis-aligned
I'm sorry, but I do not think you have any control over this other than to make sure the link is not split between two lines.
yvwinteler
How can I stop the link being split on two lines ?
For example, you can try to make the link shorter or the object wider so the link does not wrap.
