Is it possible to fix this problem?
i can't install de extentions
error reading zip local header
Re: error reading zip local header
It sounds like you have a corrupt download.
- remove the downloaded file
- clear your browser cache
- reboot your computer
- download the file again
Or use a different browser to download the extension
http://extensions.quickandeasywebbuilder.com/
