Multiple workspaces and multiple web sites
ships158
Post by ships158 »
I am a new user of QWB but not of programming. I find that I often want to have workspaces from two or more web sites open at the same time. In all other similar programs I use, the Windows Menu item in the Toolbar will always list the open workspaces as named in QWB regardless of the web site.. This makes it quick and easy to switch to a different workspace regardless of the Web Site. I can always use the Site Manager for a different page in the same Web Site but it would be nice if the Site Manager could show all open Web Sites.
Any suggestions as to how ( or if) this can be done in QWB?
Thanks.
Myron
QWB 7.2.2 on OS 10.13.6
Re: Multiple workspaces and multiple web sites
QWB does not support multiple workspaces. But you can open multiple instances of the application.
ships158
Post by ships158 »
Thanks. That is what I have been doing. It works, just not the way that I had thought it would. Sometimes it is hard to get rid of old habits.
Take care.
Myron
