I hate to expose my ignorance but here goes. This should be really simple but I cannot figure it out. The best example I can think of is when I have a template with an image in it. I select the image and I want to drag an image from my disk to replace the template image or placeholder in the template. I can paste but that does not work either.
Is there any way to maintain the select the template image shape and size when bringing in a new image?
Inserting image into a box
Re: Inserting image into a box
To replace the image:
- double click the image
- select the image from your disk
Or in the properties change the filename or select another image via the browse button.
