ERROR LOADING
DoctorWeb
ERROR LOADING
Post by DoctorWeb »
I'm suddenly unable to load up one of my qnb files,
It is in the same folder as the App, and as all the constituent object.
I get a small window pops when I try and open it , it says ERROR LOADING and the No 7. (This is Quick n Easy WB v7.3).
Another 6 web sites I have prepared all open perfectly, even ones that I haven't update since v5.
But one particular site just refuses to open up. It first did this about ten days ago, but I fixed it by moving the objects folder into the same folder as the .qwb file. But now it refuses completely.
Any more ideas would be very welcome; I would hate to rebuild this site from scratch (about 60 pages, each with four widths for responsiveness). Is there any way I can pick apart the qwb files and do it bit by bot or something?
Re: ERROR LOADING
Maybe the file is corrupt?
Did you try to load it from a backup?
It is not possible to load only parts of the project. However, if the same project loaded a couple of weeks ago then it should still work now, unless the file has become corrupt for some reason.
DoctorWeb
Re: ERROR LOADING
Post by DoctorWeb »
Must have been a corrupted file then as it wont open - just the Error Loading window displayed.
The solution was to climb on board the Mac "Time Machine" and scoot back two week, find the QWB file and restore it to tray'd desktop. I lost the last two weeks work, but by making changes 'stage by stage', then uploading and checking, I only lose a small amount.
Two major tips for others -
1. go back in the Time machine, and
2, don't make many changes before loading up and checking its all OK.
