WebShopping
michling
WebShopping
Post by michling »
I take it this does not work any longer.
https://www.quickandeasywebbuilder.com/webshop.html
Is there an update or something similar?
Re: WebShopping
What make you think this does not work? It uses standard PHP code, so it not directly related to the QWB version.
Alternatively you can try this:
http://www.quickandeasywebbuilder.com/f ... =1&t=44071
Re: WebShopping
The https://www.quickandeasywebbuilder.com/webshop.html looks pretty neat and easy to use. does it support only PayPal as the payment method?
Thank you!
michling
Re: WebShopping
Post by michling »
Pablo wrote: Thu Jun 04, 2020 6:24 am What make you think this does not work? It uses standard PHP code, so it not directly related to the QWB version.
When I try to use the demo, I get this:
Fatal error: Uncaught Error: Cannot use string offset as an array in /homepages/26/d368084380/htdocs/support/webshop/cart.php:48 Stack trace: #0 /homepages/26/d368084380/htdocs/support/webshop/cart.php(16): AddToCart() #1 {main} thrown in /homepages/26/d368084380/htdocs/support/webshop/cart.php on line 48
When I put it on my webserver, I get a simular message?
I will try the other one. Thanks
Re: WebShopping
The error is related to the PHP version.
For newer versions of PHP please change
$cart = isset($_SESSION['cart']) ? $_SESSION['cart'] : '';
to
$cart = isset($_SESSION['cart']) ? $_SESSION['cart'] : array();
