Website does not open in MacOS Catalina
GerritLachaert
Post by GerritLachaert »
My website www.gerritlachaert.be is created with Quick 'n Easy Webbuilder 7 and since Apple upgraded the OS on Macbook laptops to MacOS Catalina, I cannot open my website anymore in Safari, also not in Google Chrome under MacOS Catalina. On an Ipad and on a Windows PC, the website works perfectly.
What can be the reason ? Can anyone try to test and provide me with some advise ? Do I need to adjust some settings ?
Thanks,
Gerrit
Brussels, Belgium
GerritLachaert
Re: Website does not open in MacOS Catalina
After quite some research I detected that Avast anti-virus was blocking my website as 'not secured'. How can I make my website secured ?
First note this is unrelated to the pages created with the software.
The HTML pages are secure, unless you have added insecure script to the page yourself.
But the message may be related to the use of the URL:
http://www.gerritlachaert.be/
I think it should you should use
https://www.gerritlachaert.be/
If you do not have a valid certificate then you will need contact your web host for further assistance.
