Moving from WWB to QWB
Ok, I made the move and gradually leraning how to use it. It is definetely different, it is also missing some of the functionality I got used to, but on the positive side, the project file is smaller and gradually, as I get used to the mode of operation, it will be OK.
The one MAJOR function I am missing is : Importing a Webpage from another project.
I tried the HTML page import, it imported just a small part of that html original page.
Any tips maybe somone here can offer?
Thaks
Re: Moving from WWB to QWB
Here is what you can try:
- open two instances of the application, one with the original page and one with target project
- create a new page in the project
- select all objects on the orginal page and then copy/paste to the new page
Thanks again, until now I didn't try to run multiple instances...
Works fine
