Text is different in Google Chrome while in app
When I edit text and design it, it has different line spacing than on the Preview mode in Google Chrome. Can it be fixed?
See example on screenshots attached.
Thanks.
Re: Text is different in Google Chrome while in app
Did you try the 'compatibility option in text properties?
or else try to adjust the 'line-height' setting in the page properties.
Actually no, I was not aware to these settings. Thanks.
Did you know that if I enable Response font it disable the line-height setting?
Thanks.
If you enable responsive fonts then line height is always included.
