Bootstrap objects in qwb
Can I add such objects into qwb?
I mean, from outside sources?
Re: Bootstrap objects in qwb
You can use the HTML object and Page HTML to insert third party code.
https://quickandeasywebbuilder.com/add_html.html
Of course, some knowledge of coding is required.
Thanks, I will follow that, I just thought someone in the forum could show an example.
