HTML5 video clip player
I am trying to use this object here : https://ourvilla.net.au/funnyclips.html
But, if I enable Lightbox, all the clips become hidden.
I would like that when a visitor click a clip to play, it will come up into a Lightbox
How can I do that?
Re: HTML5 video clip player
- enable light box
- specify a preview image
That works fine now
Is this documented somwhere?
Thnaks
It works the saem as for YouTybe and Vimeo videos.
This is documented in the help.
Not so.
I used YouTube and Vimeo objects in WWB and never had to specify a picture to make it visible.
But, maybe I never tried to play the clip inside a Lightbox then...
It works the same in WWB. You will need to configure an image otherwise it will not work.
Yes, I did it works OK
