LightBox - default size setup
I am using it here : https://ourvilla.net.au/musicclips.html
To play some video clips, set in the page properties to prettyPhoto style
In the documentation, I see this :
<script src="js/jquery.js" type="text/javascript" charset="utf-8"></script>
<link rel="stylesheet" href="css/prettyPhoto.css" type="text/css" media="screen" charset="utf-8" />
<script src="js/jquery.prettyPhoto.js" type="text/javascript" charset="utf-8"></script>
But, where in the web site should it go? - is it the home page for the entire site? IF so, where in that page?
I see there a scrip... very long. But I only want to setup the box dimenssions...
Re: LightBox - default size setup
The software will automatically add these scripts to your website when you select prettyPhoto. There is no need to manually add the scripts yourself.
Ok, but, how can I set the dimensions for the page to become global?
You can add custom code via Page HTML.
Yes, but how? I can't find any documentation for that
I cannot tell you the exact code for Pretty Photo, for me, that may also take a few hours to figure out.
So, I must wonder...
If I can't get help here for a facility provided in the package
Where can I ?
This is not related to the software. PrettyPhoto is a third party script.
It is included to make it easier to add it to your website. However, I cannot give support on the behavior of the script because I have no control over that.
Is there any type of Lightbox that is configurable in QEB?
OK, thanks
All lightboxes can be configured, but each lighbox works different. So, they all have different settings.
The included lightboxes were added on request of other users, so I have included the basic configuration.
If you need more advanced option then you will have to read the documentation of the specific lightbox.
I am trying,
Can you give me ONE single lightbox type that I can configure just width / height. This is the ONLY advanced configuration I need
Fancybox supports width and height options.
