New computer no images
I have a new computer and I am trying to load my back up but all the images are gray.
How can I fix this?
Thank you.
Re: New computer no images
Did you also copy the project folder, which contain the images?
Did you make sure the folder is accessible for the application? The folder may be protected or sandboxed.
If the location of the images is different than on the other computer then you can use the Asset Manager to update the paths.
I have copied the whole folder.
The new folder has a different path. I can not update 400 images manually this makes no sense.
Is there an alternative to the Asset manager? The images folder still exists on the same folder.
If you copy the project folder to the same folder as the project then the path will be updated automatically.
Also, in the Asset Manager you can update the path for all images at once.
