*** SOLVED *** Responsive Menus
kgnoble
Post by kgnoble »
Hi Pablo
Sorry to bother you again but I am tearing my hair out having worked on this problem continuously for three days!!
I am having a problem with all of the "hamburger" type menus, which I want use for a responsive mobile page. I can see them working in preview, but when I publish them (currently the Panel menu) and look on my mobile (Pixel 3a) the icon appears but no menu sliding out.
Strangely, in a previous project the Panel menu worked well. However if I try to copy and paste the menu or replicate the settings it doesn't work!
Any ideas? I have tried just about every different setting, and I am starting a new project from scratch which still does not work on my mobile
Project file at http://cageyenne.co.uk/transfer/2020_10 ... w_1251.qwb
Keith
kgnoble
Re: Responsive Menus
Post by kgnoble »
Problem solved - I think!
I have deleted all files from the server and re published and it seems to work now!
Sorry to have troubled you
K
