Card link settings
Card link settings
I was wondering if there is a way for the Card object to remember my link settings.
Everytime I open my project -> Edit card -> Edit button -> Change link to Website: # -> OK -> Save and Exits Quick n Easy Web Builder -> Then re-open my project and edit the Card object it forgets my settings (Website: #).
How can I make it not happen?
Thank you.
Re: Card link settings
What is the purpose of using '#' for a button? it it not a valid URL.
If you want to link to a bookmark on the same page then you can use anchors.
Or simply select the page itself for 'page in this project'
You suggested me to use this method when adding Button on cards and when you put the mouse on a button there should be a cursor indicator and not text selecting indicator.
You will get the same effect if you link to the current page.
No, it's overriding my Button events.
Did it work previously?
When did it stop working?
It always behaved like this, but now it begins to become really annoying and I realized how much time I spend on this everyday.
If you can fix this then I would really appreciate it.
Thanks again.
