METE TAGS. User defined
DoctorWeb
Post by DoctorWeb »
Every 20 pages or so I get a problem with the text that I insert in the box
User defined Meta Tags under Property Inspector,
the text suddenly appears in a text box as the first thing on the page after hosting.
It doesn't appear before sending
This can be eradicated if I put it inside < > symbols, if I add. meta content=
9 times out ten it is fine.
Does this indicate a problem with the page ?
thanks
Re: METE TAGS. User defined
The correct syntax of user defined meta tags is:
<meta http-equiv="Cache-control" content="no-cache">
<meta name="expires" content="tue, 01 Jun 2015 19:45:00 GMT">
