Blog object - how to?
theheerenhouse
Post by theheerenhouse »
greetings,
In preparation of a new web design that I have to make, I started reading the introduction about inserting a blog object.
http://quickandeasywebbuilder.com/blog.html
Somehow I do not seem to be able to find the starting point beyond inserting the blog object itself. (insert, advanced, blog)
The introduction text shows a 'miscellaneous' frame that I am not able to find, let alone customize.
Nor can I find the pre-defined layouts.
Since I'm stuck now with no answer to be found anywhere else, I decided to ask for a suggestion here.
Thanks,
Paulus
Re: Blog object - how to?
You can find the Blog object in the 'Advanced' section of the toolbox. it is also available via the 'Insert' menu.
To add it to your website, drag & drop the item to the page.
Double click the object, to add new items. The style can be set via the Property Inspector.
