Window sticks to Top Left corner of screen
DoctorWeb
Post by DoctorWeb »
Suddenly, my QnEWB windows are all fixed to the top left corner of the screen. This doesn't happen with anything other applications windows, just QNEWB. It must be some control io have triggered inadvertently. Can anyone tell me where / what i need do to release the windows?
Many thanks
Re: Window sticks to Top Left corner of screen
I am not sure what you means exactly.
What does it looks like?
Which version do you use?
And which platform?
DoctorWeb
Post by DoctorWeb »
QnEWB v 7.4.0, on Mac OS 13.6 (High Siera)
The window stays firmly lodged in the top L part of the screen and will not move, as though its locked in position.
Do you have a screenshot so I can see what it looks like?
Note: on MacOS you can reset the window position by removing the 'Persistent_Options' in:
/User/Library/Application Support/Quick 'n Easy Web Builder 7/Quick 'n Easy Web Builder 7 Preferences
