project file problems
maz42
Post by maz42 »
Recently updated to QNB 8.
Working on minor content changes a a couple of small layout changes to working website.
made changes and previewed in browser, working fine - saved project as new file twice. No errors reported.
App later crashed with continuous wheel of death on attempt to set element sizing in breakpoint.
Reopened app and tried to open saved versions of project.
Errors
first 3 errors:- Error loading: CWWebAudioVideo
then continuous blank errors until force exiting app.
QWB file looks fine and right size (same as previously working qwb file in same folder).
Is this file corruption ? Is it a path problem?
Any suggestions as what is going wrong?
Re: project file problems
I'm sorry, there seems to be a problem in the audio/video object.
I will release a fix for this within a few hours.
Note that you cannot open a project that was saved in version 8 in an older version, because older versions do not support the new features.
The 'hotfix' is now available. Just re-download the software and install it over the current version.
Note that you may need to open a previous backup of the project, before you saved it in QnEWB 8.
