SVG images
pesit
SVG images
Post by pesit »
Good morning,
one (maybe wrong) question from new user:
Can I (and if yes - how) use svg images in QuickAndEasyWebbuilder? I have Wysiwygwebbuilder too and there is no problem with svg. After export project to qwb is nearly everything perfectly working. I see "img" in ObjectImager, but svg images are visible just as line and is not possible to change parameters in PropertyInspector. After PreviewInBrowser I see everythin correctly, even with Events imported from Wysiwygwebbuilder.
Quickandeasywebbuilder 8 64bit
Ubuntu 20.04 64 bit
Than you so much!
Petr S.
Re: SVG images
Unfortunately, SVG rendering is not supported by the development tools that are used to create the software.
So, therefor this functionality is currently not available.
pesit
Re: SVG images
Post by pesit »
Pablo, thank you for quick reply. Well, I will use standard image formats. And I hope that you will add svg support to some future versions of your solid software.
Petr S.
