hCaptcha question - Version 8
psaldari
Post by psaldari »
Hello and many compliments for the version 8, there is a lot of new cool futures! (I bought it immediately)
Where I find instructions to add a hCaptcha on my forms? In the Toolbox panel I find only reCAPTCHA.
Paolo
Re: hCaptcha question - Version 8
I used the instructions in the Quick ‘n Easy Web Builder PDF file.
Open Quick ‘n Easy Web Builder -> Help -> Quick ‘n Easy Web Builder Help.
psaldari
Post by psaldari »
OK, done.
But now (after compilig the form and hCaptcha have verifid I am human) if I push the submit button (Invia) the message do not goes and I am sent to the error page.
http://www.aprisogni.it/contatti.php
Any help?
I cannot see what you have done based on the published HTML code.
To be able to help you, I need a demo project which contains (only) the form, so I can see also your settings.
See also:
psaldari
Post by psaldari »
Thank's Pablo but...
I have read the hCaptcha privacy disclaimer and it is another GDPR nightmare...
OK, for now I delete it in my form.
Paolo
P.S.
By the way, I have test Google reCaptcha 2 in the same form and it works as aspected (and, of corse, I have delete it too)
