Update to version 8 with 50% discount
I send a cuopon request but didn't get any email response
I am waiting
Re: Update to version 8 with 50% discount
You should get the coupon on the screen immediately.
If this does not work then you have entered the wrong information.
I have tried it with your email/serial number and it works correct:
https://quickandeasywebbuilder.com/upgrade.html
