When loading the project : https://ourvilla.net.au/frontpage.php
To this front page, it comes up with an error : https://ourvilla.net.au/missing_images.jpg
Asset Manager doesn't help me find what is missing.
How can I find out what is missing, so that I can fix it
Error loading project
Re: Error loading project
What did you do before you got this message?
Maybe you (re)move the images?
Or maybe you did move the project but not the images folder?
I don't recall removing any images.
Maybe I did, my question remains, how can I find out which images are missing?
Happy new year, hope the UK manages to reduce and resolve the vivid pandemic.
You can use the 'Asset Manager' to see which images are used by the project and where the application is looking for the images.
You can also use it to update the location of the images.
Happy new year!
Happy new year!
Yes, I know that - but it seems there is now way for me to check which images are missing.
All the best
All the best
The Asset manager displays whether the image is OK or Not loaded.
