Opacity for Shapes
Opacity for Shapes
I am trying to add Opacity to shapes but the software just seems to ignore my Opacity update.
I am using OS X.
Here are my steps for you to re-produce:
1. Insert a Shape.
2. Fill with any color.
3. Select more colors.
4. Update the opacity.
5. Click ok, nothing happens on the software the opacity stays 100%.
Thank you.
Re: Opacity for Shapes is not working
You cannot set the opacity via 'more colors' because this standard color picker only returns the RGB color data.
But you can set the opacity via the 'Opacity' property in the Property Inspector. Or via the 'Fill Alpha'
Ok thanks.
Must say it's a bit confusing user interface wise.
