Updating Dialog design
I am using the Dialog object with Dialog Mode of jQuery UI.
How can I set the design of it? Seems like no matter what design change I apply, I can't manage to see it on the dialog.
Thank you.
Re: Updating Dialog design
Did you uncheck 'Use jQuery Theme'?
If you need further assistance, then please share a demo project so I can see what you have done.
