wbx2xmz
vincen
wbx2xmz
Post by vincen »
Hello,
I use QEWB on MACOSX, I used the wbx2xmz software to import the extensions I developed with WWB.
The problem is that in the projects I imported the name of extensions appear with .wbx at the end (div.wbx instead of div).
So they are not recognized. It is therefore necessary to recreate them. It is not very practical when they are numerous.
Thank you in advance for your answer
Vincent Blanc
Re: wbx2xmz
It is not clear to me what you have done exactly. Can you please more specific?
Extensions created with Extension Builder have the extension .wbx.
Note that this tool is provided "AS IS".
However, it works correct for me, I have used it hundreds of times myself.
vincen
Re: wbx2xmz
Post by vincen »
Hello,
Here is a screenshot of my problem:
See the div component in the toolbox and div.vbx in the page which should normally be div
To fix this problem I have to delete the div.vbx components and recreate them as div
Greetings
Vincent Blanc
Re: wbx2xmz
Sorry, I do not understand why you have to recreate the extension?
Why do you need to do that? What is difference before and after? It is the same file, right?
