Panel Menu Erratic In Breakpoints
protectourlands
Post by protectourlands »
I cannot get Panel Menu to maintain its settings when adding breakpoints to the page. It seems to want to revert to black icon white button as soon as I add a breakpoint to Default.
To duplicate: New page, add panel menu to Default. Button text "=" for hamburger. Make button background black and text color white. Shows fine on workspace and previews fine. Now add a breakpoint. The Panel Menu changes to black hamburger with white background in default when previewing, and in the breakpiont workspace I see a gradient background. It seems to go haywire as soon as I add a breakpoint. Is there a setting I am missing?
Re: Panel Menu Erratic In Breakpoints
Thanks for the information.
I was able to reproduce the problem and it will be fixed in the next update.
protectourlands
Fantastic. Thank you Pablo
