Disappearing objects
DoctorWeb
Post by DoctorWeb »
Disappearing Objects
Im getting some objects 'disappear' in different 'responsive sizes.
Both Text boxes and images are fine on the QEWB pages, they upload OK,
but when I look at them off the host - just a blank empty space.
I've switched off completely the 'lazy load' options on images (that was causing ALL my images to never load up at all.)
But the text objects are worrying - I have tried taking a 'visible' box, duplicating that and adding the text into there, but it still doesn't appear.
Even a 'new' text box added will disappear after being served.
I was thinking this is due to viewpoints, but I only use 4
(1290, 7868, 414 and 320).
toggled 'off' (using the button at the top of the Object manager)
I also get objects arbitrarily 'appear' in certain sizes, when they are clearly.
(These are not 'ghosts straying outside layers or anything - just 'stand alone' regular objects)
Im using WEWB v8-1, on a 27inch iMac running OS 13.6.
Many thanks for any help or suggestions
Re: Disappearing objects
To be able to help you, I need to see what you have done.
Do you have a demo project?
DoctorWeb
Post by DoctorWeb »
I dont have anything set up as a demo, all my web sites are live - and all done with V8 have big holes where objects (text and images) are showing on the workspace, but disappear once sent to hosting.
Would you be able to see the problems if I send a QWB file to you, or do you need the full folders of 15 to 45 MB, with all the objects in it as well?
What is the URL of the problem page and where on the page do I need to look to see the problem?
I do not need your complete project. Only a demo project with one page, so I can see what you have done.
DoctorWeb
Post by DoctorWeb »
https://radio270.net/Shop.html
Fine in 768 and 1280 (Default)
but on 414 and 320, items disappear.
Objects are there on the workspace, but not after hosting.
I've added new objects in as new, copies of ones that appear fine elsewhere on the page.
Many thanks
Sorry, but I need your project file to see what you have done.
Because there is too much content to make any sense of the HTML code.
Also, I need to know the IDs of the missing objects.
DoctorWeb
Post by DoctorWeb »
That will be time-consuming,
But I may have found a solution of sorts, editorially.
I wonder if objects not appearing could be a responsive window size problem, <
I had some that appeared in, say a 414 window, when they are clearly greyed out for that size, but they don't appear in windows they are 'activated for'.
I have duplicated them and got different results. Compared everything in the Property Inspector box,
but getting a headache as the boxes for that and Object Manager as so difficult to see.
Need to take a break from it, I shall get back when I have some clearer material for you to work with.
Thanks anyway
I'm sorry, but the software has thousands of options and millions of possible combination so you will need to be more specific. Otherwise I cannot give any meaningful advise about this.
I need to know which objects (ID) disappear and how it looks in the project.
