Page Properties? hidden?
DoctorWeb
Post by DoctorWeb »
I thought I should homogenise my pages, instead of every page a 'from the bones' wholly new construction, so made up a design for a 'Master Page'.
The instructions say:
Step 2
To use the master page in another page:
- Open the Page Properties->Miscellaneous
- Click Select to the select page.
- Set Type to Master Page
I have scoured the QEWB application from top to bottom, side to side, and nowhere can I find anything to do with "Page Properties - Miscellaneous"
No page Properties, and even under 'Page' in the top menu bar, nothing has anything about properties or miscellaneous.
So where is this mysterious, enigmatic 'Page properties' hidden?
Many thanks if anyone can steer me towards it.
Re: Page Properties? hidden?
In the page properties (property inspector int the right-bottom corner of the workspace) there is a dedicated section for the master page.
Set 'Enable master page' to 'true', then you can select a master page.
DoctorWeb
Post by DoctorWeb »
Thanks, I can see it now
Switched on, and the master page does appear - though Im not certain why the responsive navigation bar will not tuck inside the header box. - It just remains at the default size, meaning I cant use it.
But this is a great start
Cheers.
If you need further assistance then please share a demo project so I can see what you have done.
