Shadow to cards
Shadow to cards
It seems like when adding Shadow to Cards and updating the parameter: Shadow Alpha on Breakpoint mode it remove the change once you reload your project.
How to reproduce?
1. Add card in both regular and breakpoint mode.
2. Add Shadow Blur and update the Shadow Alpha on both Desktop and Breakpoint mode.
3. Save file.
4. Reload project and select the same card.
5. Shadow Alpha is back to it's default value.
How can I solve this?
Thank you.
Re: Shadow to cards
It seems to work correct.
Note that a breakpoint is just a variant of the same page but with different properties. But the alpha value cannot be different.
